Justin, If you want to stick with Rockford. The P300-1 will do 300 watts mono at 2 ohms. The woofer you probably have is the dual 4 ohm. So wire it in parallel making it a 2 ohm load. That woofer is rated at 300 watts rms. So you will be right on as far as power. Tim Wet Sounds
