04-19-2006, 8:15 PM
I am almost done with my sub set up and the guy that was going to help me is to busy right now. So now I need to finish it myself. What I have is a JLW7 12" in a box with a plexyglass front window. Now what I need to do is put some sort of plate over the front to make it look nice and since I have zero creativity I need to use somone elses idea. Thanks for any help given, Mike
04-19-2006, 9:25 PM
04-19-2006, 9:44 PM
The second one is close but mine has a plexyglass window and the sub is not facing out. I will get some pics up first thing in themorning. Thanks for the pics. Mike
04-19-2006, 10:57 PM
Wait till Clay or Grant see this post.... Pictures galore
04-20-2006, 4:37 AM
04-20-2006, 6:21 AM
04-20-2006, 6:36 AM
? on those with subs in the hatch ? How do you work on your boat? Change the impeller, oil, plugs, bilge... I think the craftsmenship is great & bet it sounds savage + the weight is good!!! Just concerned on maintanence issues? Lzy
04-20-2006, 7:25 AM
04-20-2006, 7:25 AM
William, How does that sub sound with that enclosure? I made one that looks just like yours, but mine turned out to sound better under the dash without the sealed box. Also, did you make that playpen yourself?? It looks good.
04-20-2006, 7:30 AM
Cartronics, what did your shop charge to build that slotted port box with the w7 in it? Is that in a malibu?
04-20-2006, 8:39 AM
04-20-2006, 8:45 AM
I will most likely turning to fire to the right. The guy who help me build it designed it to fire into a sound bord but I did not like the vibration the back pressure caused on the sub. Mike
04-20-2006, 9:08 AM
I just played a little Prodigy in the boat and definatly is getting turned to the right, I thoguht the whole boat was going to fal apart. Now I just need to figure out how to build the exterior panel. Mike
04-20-2006, 9:09 AM
PMH the enclosure is built to .615 cubic feet of airspace and JL reccomends .625. i went with a slightly smaller enclosure because im running 600 watts to each of my W6v2's. the sub will only sound good if it has the right amount of airspace and if it isn't in a enclosure you probably wont get alot of output. The sub is located under the bow filler cushion and then i made the grill with matching mesh.
04-20-2006, 9:28 AM
04-20-2006, 11:31 AM
Thanks Shane. That is exacly what I need to do. What is that board made out of? Mike
04-21-2006, 8:12 PM
Well I got it finished today. I used the stock kick panel and modified it to work with the new sub. I might change it out later but it looks ok for now. I will post some picks tomorrow. Mike
04-21-2006, 10:01 PM
The things people will do for a little bass.....
04-22-2006, 8:33 AM
MIke-On your Bu why did you choose to fire the sub sidewayz ? Just curious if it sounds better then facing back towards the cabin ?
04-22-2006, 9:40 AM
Well the the box was designed to fire up but that was no good so the only other optio was to go to the side. It does sound great though. I can't wait to get it in the water to hear it. Mike
04-22-2006, 9:58 AM
I see alot of sidewayz firing subs on this thread and was just curious if the deflection helps or if it was just a fitment issue. Thanks
04-22-2006, 11:03 AM
I think the deflection helps. It sounded way better once I put it in then it did just sittiing out on the floor of the boat. Mike
