Old     (ladythump)      Join Date: Jul 2004       08-31-2005, 1:29 PM Reply
Is it possible to do a 1 wake 360? I'm still working on getting w2w. Been practicing 1 wake 180s and half cabs. Just wondering if a 1 wake 360 is possible or will I kill myself?
Old                08-31-2005, 3:35 PM Reply
yes its very possible, i reccomend learning it that way as well.
Old     (hypo303)      Join Date: Jun 2004       08-31-2005, 5:52 PM Reply
I would recommend learning w2w jumps and both ts and hs 180s first. You can take some pretty bad falls with 360 one wake or two wakes, because of the handle pass. Take your finns off and maybe try some surface 360. My opinion get the basics down first. Not to scare you I got a concussion last sat doing a two wake 360. I was wearing a helmet also. I have a black eye right now. Looks lovely...Wendi
Old                08-31-2005, 6:15 PM Reply
get your basics down like HYPO said, its crucial to progressing in wakeboarding and the harder tricks will come more easy. but if you are really insisted on learning the 360 i would reccomend on working on switch bs 180s first. also do the surface 360 just as it would look in the air that way you get used to the handle/body position. you can also try this off the roller on your turn around (not the DU).
Old    alanp            08-31-2005, 6:37 PM Reply
dont even consider a 360 if you can jump wake to wake. just doesnt make sense and your likelihood for injury is pretty good. and what 1/2 cabs have you been working on? 180's, riding switch, jumps? to answer your question it is very possible, i can do them one wake, off of rollers, and ollie, but i had a decent foundation before i tackled those tricks. good luck
Old                09-07-2005, 6:44 PM Reply
I would let the rope out to 75,80 feet.This will give you a wider area to land without hitting the other wake. When you do start landing your 3's bigger then shorten up the rope and go wake to wake. It takes the pressure off landing wake to wake so you can concentrate on the 3.
Old     (ladythump)      Join Date: Jul 2004       09-08-2005, 5:54 AM Reply
I can land the hs 1/2 cab and the ts 180. Good idea about the longer rope. I might try that.
Thanks.
