04-21-2008, 8:41 AM
Question: I have 4 rockford fosgate tower speakers in the polished (bullet-like) cans -- like most who ordered directly from Malibu for 2007 model year. I have the whole rockford fosgate stereo setup that the option came with (3 amps, sub, ect.). If I swapped the tower speakers out for wetsounds (not sure which model) - would the music be any louder behind the boat? I guess my situation is, I don't want to mess with anything else - amps, setup, or anything. I want to bolt on the wetsounds, but if it won't sound louder, I am not really interested... any one that can chime in on this? Thanks!
04-21-2008, 8:47 AM
OMG yes there is no comparison.
04-21-2008, 8:47 AM
Mike, Adding 2 pairs of PRO 60X's to that tower without changing anything else. WILL be a very large increase in volume. Since you will be going from a car audio based system to our pro audio based system. Tim Wet Sounds
04-21-2008, 8:53 AM
HUGE difference. The RF amps might need to be upgraded too.
04-21-2008, 9:18 AM
The tower speakers that most boat companies put in the boats stock are a joke. Wetsounds will be at least 5 times louder than the rockford fosgates.
04-21-2008, 9:30 AM
Someone needs to write a few paragraphs and explain the mechanics of why HLCD is much more applcable in fixed direction sound projection than a typical dome tweeter, that way when this topic comes up, it can be directed to and would have much better information than the typical "YES, it will be much louder" reply.
04-21-2008, 9:42 AM
Rather than bolting in car audio speakers, you might look into getting the Bullet Hollow Point 650's. They are HLCD pro audio speakers and Bullet is selling the speakers only. So if you have cans you can now upgrade to HLCD. Check www.bulletspeakers.com to see if they will fit in your Metcraft cans.
04-21-2008, 10:07 AM
No one is going to even say that it may not be that much louder?! Like you guys are all 100% sure it will be louder by a noticable level out on the water - without changing anything about my setup besides the speakers in the cans? Stewart, I would definitly consider that idea - are the Bullet 650s compariable to the wetsounds 6.5" speakers? From what I have found, wetsounds won't let you just buy the speakers correct? If I could avoid buying new cans and trying to sell mine, I would save a little. Thanks guys - you are great, but also terrible since this will cost me some coin, but I would really love that increase in volume!!!
04-21-2008, 10:22 AM
and so will your riders. Fellow boaters may not so much depending on your flavor of music.
04-21-2008, 11:19 AM
mike, Wetsounds sells there XS-650 separately, which is a 6.5" car audio coaxial speaker. Used mostly for interior. The Hollow Point 650 is an HLCD similar to the Wetsound Pro 60X.
04-21-2008, 11:38 AM
mike, No one is going to tell you it will not be much louder b/c it will absolutely be louder with ANY compression driver. It is all in the way the sound is projected. An HLCD directs the sound into a tight area vs. a typical dome tweeter which scatters sound evenly about. Think of someone yelling through a rolled up piece of paper, or placing their hands around their mouth to project the sound. You can hear better on the open end, and not so much on the sides. That is essentially what an HLCD does (there is much more to it). It is able to more efficiently direct the sound to a fixed area vs. the scattering in all directions that a typical dome tweeter does. Wetsounds has been recommended to you b/c of the customer service buyers have received and the materials used in their manufacturing. They are a true marine HLCD setup. One downfall (other than a huge price tag) HLCD has is that they truly perform when they are given appropriate power. You may need to upgrade an amp to run them at a volume that makes you happy or makes you feel like you got your money's worth. It's not so much the HLCD needs the power, but rather the entire system that you would purchase. HLCD actually have relatively low power reqs. (Message edited by olSkoolTige on April 21, 2008)
04-21-2008, 2:19 PM
I actually use less amp power with my addictions than with my older sklons, similar volume in the boat, but WAY LOUDER behind the boat
05-01-2008, 8:27 PM
I would say that Wetsounds require a lot more power from the Amp than normal car speakers. I went searching for a 2 channel 250 RMS Amp today. Only the most powerful Amps available push 250 RMS X 2 continuously.
05-01-2008, 10:44 PM
Mike, All i can say is wetsounds company slogan...Hearing is BELIEVEING. I went from 4 6x9s to two PRO 485s and it is clearer and at least5 times louder and travel much further.
05-02-2008, 3:00 AM
the difference will be night and day. like a yugo to a vette. all the new tiges have the wetsounds speakers and i have been looking at them i am blown away by these speakers. i liked them so much i changed out my in boat clarions to the wetsounds 650s and WOW what a difference. im going to change the sub next and then the tower. its a real no brainer to me wetsounds are just that much better. good luck in your decision!!
