Old     (spicychalupa69)      Join Date: May 2005       05-13-2009, 4:36 PM Reply
So I got my HSE installed. I want to program it so that it turns the volume up/down around 2500 rpm's but have not been successful. What I do is put the boat in neutral and rev the engine up and program it. When I program it that high the volume jumps up and down and up and down until we are up to speed and it stays. I have only been successful in programming it at 1000 rpms without any fluctuation of volume. Any tips?! Thanks in advance!
Old     (wakeprodigy)      Join Date: Oct 2002       05-13-2009, 5:08 PM Reply
Eder,
It's helpful to maintain a consistent RPM level when programming. Try this:
1) Rev engine to desired RPM level and hold that level for a few seconds to let the RPMs stabilize.
2) Hold the program button until the Program LED starts blinking. Release button when LED starts blinking.
3) Once LED stops blinking the RVC is programmed.
Also try emailing Jim at sales@hsetrident.com. He should be able to respond to your emails faster than posts on Wakeworld.
Hope that helps
Old     (spicychalupa69)      Join Date: May 2005       05-13-2009, 5:14 PM Reply
Thanks Tom, will do both!
Old     (johnny_jr)      Join Date: Mar 2006       05-14-2009, 8:13 AM Reply
I've installed a few of these and have never had this come up, Try the process Tom stated... You should be just fine. If not you will need to confirm that you located the correct wire carrying the tach signal. On new BUs it's the grey wire at the ECM in the engine compartment.
Good Luck!
