In general, you would pull the prop shaft cotter pin, then back the nut off til it's close to the end but still on. Next position the prop puller and start tightening down a few turns, then a light hit on the end of the puller shaft with a hammer and it should pop off, if not, tighten some more and hit again. If it's real stubborn, a propane torch for a little heat might help.
