thanx for the replies boys. by chance if I do decide to hook up a more permanant system, can a couple of you post some pics or diagrams with fittings that you have as well?? not sure if i want to drill through the hull, but a semi/permanant system might be in order. I tried reading through some of the posts, and all i read was valve this, bad valve that, water siphoning out of this setup, and over my thought capacities. Also, does a guy need 2 pumps per bag to fill and drain, or can it be done with 1 pump. (Message edited by trx-1noob on April 17, 2007)
