I have an 01 X-10, got a good bit of water in the bottom of the boat, pumped it out, next time I went out the boat had become very hard to steer. Found 2 grease fittings, one at the rudder, and another one with a piston & rod type deal just under the aft part of the engine that runs to the steering wheel. Greased both fittings, and nothing. It is still very very, did I say very? I mean very hard to steer, like a work out.
Anyone else experience this or know of any other fittings that need grease to loosen & help steering? I checked under the steering wheel and there is nothing to grease there, plus this happened right after the bottom of the boat got filled with water. So it seems like something got wet and washed grease out, which seems wierd for grease to wash out that easily. Anyone with any knowledge of this, any help will be greatly appreciated.
