Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 18, 2009
Old     (smuurph84)      Join Date: Oct 2008       03-17-2009, 10:41 AM Reply
I am trying to do my first (on my own) stereo project and I have a few questions. I had a company do the orginal install wich included adding an amp and a vsr relay. It looks like they wired the amp to the vsr relay should I do the same with the second? also they have the first amp grounded to a large screw they installed on the amp rack? should I ground it to the same point? some info I got off the boards says to use a different ground point but Im not sure what would be sufficent? any info would be great thanks
Old     (tailgate)      Join Date: Apr 2007       03-17-2009, 12:12 PM Reply
AFAIK, you need to use the same ground point, or at least at least be connected to the same ground. Not sure what a VSR relay is, but one thing to make sure is that the existing wiring is sufficient to handle the load of both amps.
Old     (smuurph84)      Join Date: Oct 2008       03-17-2009, 1:38 PM Reply
2g good enough? amps are 880 and 740 watts?
Old     (my_malibu)      Join Date: Feb 2008       03-17-2009, 4:09 PM Reply
over kill you can run the 2ga to a distribution block then 4ga to both amps
