Old     (davez71)      Join Date: Oct 2007       10-30-2007, 9:26 AM Reply
Does anyone know of a good leveling kit for a 07 tahoe and what size tires can you fit. Also what about a brush guard? Has anyone seen one with a brush guard on.. Let me know what you think.
Old     (peter_c)      Join Date: Sep 2001       10-30-2007, 9:36 AM Reply
Can you still use the F150 keys on an 07? If so they are cheap and easy to install. Then have it aligned.
Old     (maxx_wake)      Join Date: Sep 2003       10-30-2007, 9:40 AM Reply
You cant use the F150 keys on Tahoes. That only works on the 1/2 ton trucks with torsion bars. I dont think the tahoes ever had torsion bars and even the trucks have gone away from them for 07.
Old     (bbower)      Join Date: Mar 2007       10-30-2007, 12:26 PM Reply
Not true chris. I have them on my z71 tahoe. can definitely get it done. go to z71tahoe-suburban.com and check it out. there are many tahoes on there with ford keys.
Old     (pri3st)      Join Date: Aug 2007       10-30-2007, 1:17 PM Reply
He has an '07 (no torsion bars)
Did you even search David? Shall I look up brushguard for you, too.
http://www.truxxx.com/chevrolet_products/2007-chevrolet-tahoe-leveling-kit.htm
http://www.marketworks.com/storefrontprofiles/DeluxeSFItemDetail.aspx?sid=1&sfid=134402&c=706664 &i=177023406
http://www.ok4wd.com/index.php/catalog/product/bds_2_leveling_kit_for_07__chevy_tahoe/
http://rockymountainsusp.com/chevy_gmc_leveling_kits.htm
http://cgi.ebay.com/ebaymotors/07-Chevy-Avalanche-Tahoe-Suburban-2-Leveling-Lift-Kit_W0QQcmdZViewItemQQcategoryZ33585QQihZ013QQitem Z230186376913QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/Ready-Lift-Leveling-Kit-07-Suburban-Tahoe-2WD-4WD-1-5_W0QQcmdZViewItemQQcategoryZ33585QQihZ020QQitemZ3 00121929811QQrdZ1QQsspagenameZWD1V
http://cgi.ebay.com/ebaymotors/07-Tahoe-Yukon-2-Leveling-Kit-Poly-Coil-Spring-Spacer_W0QQcmdZViewItemQQcategoryZ33585QQihZ013QQi temZ230169277451QQrdZ1QQsspagenameZWD1V
Old     (davez71)      Join Date: Oct 2007       10-30-2007, 1:46 PM Reply
Thanks, Kevin i was just wondering if there were any cheap ones cause the ones i found were 300 dollars and i was looking to spend that much. I found some brush guards i just don't know about the look.
Old     (pri3st)      Join Date: Aug 2007       10-30-2007, 1:54 PM Reply
...will you be going through brush?
