Old     (typhoon)      Join Date: Jul 2001       04-21-2009, 3:14 PM Reply
I have an amp that would feed these about 110 watts each. Is that enough?
Thank you
Old     (innov8)      Join Date: May 2005       04-21-2009, 3:26 PM Reply
I would feed more like 250 watts to each.
Old     (882001)      Join Date: Nov 2003       04-21-2009, 4:30 PM Reply
A good clean 110 watts rms crossed over around 100hz should make them rock! Mids and highs don't require as much power as lows do. Do you already have that amp? If so try it for a while.
Old     (typhoon)      Join Date: Jul 2001       04-21-2009, 4:33 PM Reply
i have a 4 channel soundstream that is rated at 90 watts per channel rms at 4 ohms and using the 1 and 2 channel for in the boat. soundstream said it will play around 110 watts rms at 3ohm.
Old     (typhoon)      Join Date: Jul 2001       04-21-2009, 5:50 PM Reply
Sorry for double posting, I just saw the other kmt6 post.
Old     (chpthril)      Join Date: Oct 2007       04-21-2009, 6:52 PM Reply
I dont think that you will be disappointed with 110W's rms, but they will deff take more. Setting the amp up right will make a huge diff, does the amp have a High-Pass setting?
Old     (typhoon)      Join Date: Jul 2001       04-21-2009, 7:34 PM Reply
yes it does. It is a pretty nice soundstream with high and low pass.
