Old     (rubin)      Join Date: May 2006       04-14-2009, 4:19 PM Reply
Hey guys, I'm looking for some opinion on what some other people might do in this situation.
The boat is a 2003 Centurion avalanche. After an incident we had last season, we needed to have the v-drive replaced. Long story short, after taking it for a lake test, we found that the wrong v-drive was installed. It was a 1-1 ratio and a 1.46-1 was installed.
Not getting in to whose fault or anything, centurion recommends changing the prop from a changing the prop to a 13x17.5(497) from our 13x11(525) to solve the problem instead of swapping out the v-drive.
It seems like if this works, it works right? What is everyones take on this?
Old     (mhunter)      Join Date: Mar 2008       04-14-2009, 4:24 PM Reply
Is the people that put in the wrong trans paying
for the prop? If so it sounds good to me.
Old     (rubin)      Join Date: May 2006       04-14-2009, 4:28 PM Reply
Yes, and most likely replace our spare.
Old     (boarditup)      Join Date: Jan 2004       04-14-2009, 4:50 PM Reply
You have a great situation. The reduction drive allows for greater propping options. The hull will also allow a 13.5 prop - and 847.
Old     (krbaugh)      Join Date: Mar 2002       04-14-2009, 4:51 PM Reply
That is a free upgrade. In 2005 Centurion Switched to 1.46-1 because it swings a bigger prop and will better handle the ballast that people where putting in the boats. As long as they change out your props you are ahead of the game!!
Old     (fogey)      Join Date: Mar 2002       04-14-2009, 6:03 PM Reply
Seems like a win-win for you. I know I'd much rather have the gear reduction.
Old     (rubin)      Join Date: May 2006       04-14-2009, 7:15 PM Reply
Thanks guys, i guess we'll be back on the water in no time
Old     (luchog)      Join Date: Jun 2002       04-14-2009, 9:59 PM Reply
You also have a more expensive tranny now and better resale. just swap the prop!!!!
Old     (xstarrider)      Join Date: Jun 2007       04-14-2009, 10:18 PM Reply
Like the others have said Win Win with the gear reduction. It's an "upgrade" compared to the 1:1
(Message edited by xstarrider on April 14, 2009)
Old     (rallyart)      Join Date: Nov 2006       04-14-2009, 11:35 PM Reply
Only disadvantages are a bit more weight and noise, and more transmission heat. None of those are severe.
Old     (rubin)      Join Date: May 2006       04-15-2009, 11:26 AM Reply
weight sounds like an advantage!
