Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 04, 2009
Old     (evil0ne)      Join Date: Sep 2006       07-27-2009, 8:59 PM Reply
One of the exhaust manifolds cracked without anyone's knowledge until the floor got squishy. Got the boat back to the slip and on the hoist. I need to get it back on the trailer and to the shop for a permanent fix but does anyone have a suggestion for a temporary fix to keep the water out while idling from the slip to the trailer?
Old     (jtnz)      Join Date: Sep 2007       07-27-2009, 9:14 PM Reply
Row or tow. If you don't start the motor you won't have any water running through the exhaust.
Old     (peter_c)      Join Date: Sep 2001       07-27-2009, 9:15 PM Reply
Start paddling?
Learn to sail?
Old     (salty87)      Join Date: Jul 2002       07-27-2009, 9:18 PM Reply
if it's not too big, jb weld might help
Old     (jtnz)      Join Date: Sep 2007       07-27-2009, 9:42 PM Reply
Or duct tape, how fast is it filling? Surely you can't run that much water into the bilge between the lift and the ramp.
Our exhaust had a leak but it didn't really fill that fast. A couple of inches in the bilge over a couple of hours at most.
Old     (evil0ne)      Join Date: Sep 2006       07-27-2009, 10:18 PM Reply
The plan is for a tow, but with the exhaust being below the waterline it is filling rather quickly. I'm just looking for a temporary patch like the JB Weld idea. Obviously several ballast pumps will be on hand.
Old     (dhcomp)      Join Date: Jun 2003       07-27-2009, 10:30 PM Reply
If you are towing it, remove the flex hose between mufflers and manifold, and cap the muffler.
Old     (mtnsmith)      Join Date: Jul 2006       07-28-2009, 6:25 AM Reply
Even just stuffing a rag or something in the exhaust will slow the entry of water if you are towing. If you want the shop to repair the muffler that is in there, sometimes doable, then I wouldn't jbweld it, that will make them more than likely only look at replacing it.
(Message edited by mtnsmith on July 28, 2009)
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-28-2009, 9:04 AM Reply
duct tape your flap down. You could even silicone it then just peel it off when you get it off the water.
Old     (tpyle)      Join Date: Feb 2006       07-28-2009, 2:34 PM Reply
X2 on the JB Weld. Get enough in the crack and you might be able to delay the repair until after the riding season. I've seen JB weld like stuff used to fill in erosion on large diesel engine blocks.
Old     (wakeboardlasvegas)      Join Date: Mar 2007       07-28-2009, 7:10 PM Reply
Does jb weld fiberglass/plastic?
Old     (king_of_wake123)      Join Date: Aug 2009       08-10-2009, 5:42 PM Reply
duck tape is the best lol
Old     (mikeski)      Join Date: Aug 2003       08-11-2009, 12:20 AM Reply
Get an inflatable plumbing block from the hardware store (or just use an inflatable ball). Stick it in the exhaust and fill it up with air. You might even be able to find a kids toy ball that fits snugly enough in the exhausts to block the water intrusion.
