Old     (newwhit)      Join Date: Mar 2007       03-07-2009, 10:19 AM Reply
i have found a good deal on a 2002 Cent Hurricane with storm package III.
any opinions?
Old     (bigshow)      Join Date: Feb 2005       03-07-2009, 12:33 PM Reply
I had an 04 Lightning, same hull. The goofy wake is a bit hard to bring in. If you're going to attempt to build a goofy wake you need the Bennett trim tab, and need to set it down.
You can get a very good surf wake on the regular side but you'll need a lot more than stock ballast.
I was running the the center tank full, a FH 750 in the port locker, a 400 under the bench, a 750 on the bench and more.
The Avalanche hull is far better. If you want to surf look for an Avy.
Old     (mo_scrilla)      Join Date: Jun 2004       03-07-2009, 2:03 PM Reply
My buddie has one, thats what we ride behind. With enough weight you can get a really decent wake. we try to get the waterline to about the rub rail.
Old     (mo_scrilla)      Join Date: Jun 2004       03-07-2009, 2:05 PM Reply
This is the wake.Upload
