Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 27, 2003 > Archive through May 13, 2004
Old     (billyboard)      Join Date: Apr 2004       05-07-2004, 7:06 AM Reply
Anyone know the approximate horsepower for 1988 Mastercraft Prostar 190 with 350 engine?
Thanks
Old     (lake_side)      Join Date: Jan 2004       05-07-2004, 7:26 AM Reply
is it the 350 or 351
Old     (billyboard)      Join Date: Apr 2004       05-07-2004, 7:33 AM Reply
I have been trying to determine the engine size too. The owners manual mentions a 350 (not a 351) but the original sales brochure mentions a 351 and not a 350.
First, does that make a big difference in HP? What is it for either of them?
Second, I'll upload a picture of the engine in case that helps.
Old     (will5150)      Join Date: Oct 2002       05-07-2004, 7:51 AM Reply
I would bet it's 270 HP- It doesn't look to be fuel injected- but if so, that could raise the HP slightly. Either way, it's a good amount for a light boat.
Old     (rem_pss308)      Join Date: Mar 2004       05-07-2004, 8:08 AM Reply
That is a Ford engine. ( the distributor in the front. the Gm distibutor will be in the back.
The didnt start putting in fuel injection until 1994
I have a GT-40 351 it has 285 horses.
The standard Ford had 275 HP
You can call Mastercraft with the Vin and get the details.
Old     (billyboard)      Join Date: Apr 2004       05-07-2004, 8:14 AM Reply
Thanks Mike. Is the Ford engine the 350 or 351?
Thanks Will. It is not fuel injected.
Old     (wiltok)      Join Date: Feb 2003       05-07-2004, 8:20 AM Reply
Bill,
Had the same the same boat/engine combination. Mike is right on the hp - and the boat has plenty of power. In fact, that boat is a blast to drive, turns on a dime. Only drawback, it's a really harsh ride on rough water.
-Keith
Old    dubers            05-07-2004, 8:35 AM Reply
I have the same year Tri Star 190. It's a Ford 351 and I'm pretty sure it's rated at 275 hp like stated above.
Old     (rem_pss308)      Join Date: Mar 2004       05-07-2004, 8:42 AM Reply
Ford makes the 351
and chevrolet makes the 350
Mastercraft did not install fuel injection until 1994 so I would say it is not fuel injected.
Old     (nauty)      Join Date: Feb 2004       05-07-2004, 8:42 AM Reply
Standard HP for the Ford 351 PCM is 260hp. I could be wrong, but I think they offered an upgrade to 285hp? I have a standard FORD 351 PCM engine (carborated) and it is 260hp.
Old    deiselgrover            05-07-2004, 8:42 AM Reply
351 is Ford. They made 2 versions of that motor, the Windsor and the Cleveland. The Cleveland is 285 and the Windsor is a little less. 350 is Chevys version of the 351. Here is a pic of my 92 351 Cleveland. Either one you have is plenty of H.P.!
(Message edited by deiselgrover on May 07, 2004)
Old     (lake_side)      Join Date: Jan 2004       05-07-2004, 11:52 AM Reply
I have the same motor in my tri star and it is a 260 hores the up grade would be the gt 40.
Old     (dbjts)      Join Date: Nov 2003       05-07-2004, 11:53 AM Reply
Billy you have got yourself a 351 Ford Windsor with a Holly carb pushing out 260HP don't let anyone tell you different.
