Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 27, 2003 > Archive through September 24, 2004
Old     (pimp131)      Join Date: Aug 2003       08-09-2004, 8:26 AM Reply
I was just looking at some trim tab setups and the pamflet from Bennett trim tabs say its good for wakeboarding. Does anyone know if these trim tabs can be fitted to work properly on say a 94 mastercraft prostar 205.
What are your opinions.
Old     (malibuboarder75)      Join Date: Jan 2004       08-09-2004, 8:48 AM Reply
doesnt really make the wake bigger...maybe a little cleaner. the most it will do is allow you to raise the back of the boat to make the wake smaller. That way slalom skiers will have a better wake, then you can lower the tabs again and have wakeboarding wakes.
Old     (bdavis)      Join Date: Sep 2002       08-09-2004, 8:56 AM Reply
I would think they could make cruising at 35mph+ a lot nicer. Seems like most if not all DD, VDrives porpoise from no trim capability.
Old    ilovetrains            08-09-2004, 9:20 AM Reply
I thought one advantage of an inboard was it's inherent resistence to porpoising from having the prop under the boat?
Old     (evil_e)      Join Date: May 2004       08-09-2004, 9:55 AM Reply
Tige, Supra, and Moomba all offer trim tabs on their boats.
Old     (wake_eater)      Join Date: May 2003       08-09-2004, 4:59 PM Reply
supra & moomba use them. they call them "wakeplates". i wouldnt want to not have it now. when i'm cruising down the lake i lower it all the way and when we're riding it is usually all the way up. when it's down it flattens out the wake & when its up the wake is huge & rampy. in the down position it lifts the back of the boat creating a smoother ride, when its in the up position the back of the boat sits deep in the water.
Old     (krbaugh)      Join Date: Mar 2002       08-09-2004, 5:18 PM Reply
David and Chuck
Centurion also has the Bennet trim tab as an option. Your description of how to use it and how it works is very accurate
Old     (mikeski)      Join Date: Aug 2003       08-09-2004, 5:42 PM Reply
Like the others have said it will not make your wake bigger, just elongate the planing surface pushing the back of the boat higher in the water most likely resulting in a smaller wake.
Comparing the hull of your 1994 Mastercraft Prostar 205 to these boats designed to use trim tabs is not a real good comparison. The hull of your boat is not designed to use trim tabs it may not benefit from their addition. If you apply too much weight at the very back of the boat it may porpoise at higher speeds. It is probably easier to unload the weight then add a trim tab.
Old     (mikeski)      Join Date: Aug 2003       08-09-2004, 5:47 PM Reply
Brent,
The Mastercraft prostar like most other well designed direct drive tournament ski boats will not porpoise without significant weight added in back.
(Message edited by mikeski on August 09, 2004)
Old    jbf            08-10-2004, 1:05 AM Reply
allesandro,
if you wakeboard with a heavily wieghted prostar
the trimplate,s will only help you get on plane sooner....beside that you want them in the up position anyway.
