How do you get the drain plugs out? They both have knock sensors (unlike my 2004) which make it difficult to get a wrench around them. There is a small nut on top of the sensors doess thiss need to be removed?
Take the 1/2" nut off and let the knock sensor hang then a 1" wrench or socket to get the remainder of the plug out. I am going from memory on the size but the process will remain the same.
Yea the old one you just removed the wire and used a 7/8" to take it out. Starting in 06 they went to the new style knock sensors on both sides of the block instead of one like 05 and before.
I just removed mine this weekend. I disconnected the cable, put a crescent wrench on the big nut, broke the seal and removed it with the wire connector still on. It was on hand tight plus a little.
I had to complain about the hand tight thing because it seems like every one we have had to pull out this year when we did not have a large cresent wrench or something, was in to tight.
