07-10-2006, 8:04 AM
'06 Supra 21v. Carpeted wheelwell hull protectors popping the screws. One gouged the hull yesterday. If you load the boat centered on the runners the way it's supposed to be, the hull hits the port side wheelwell. If you center it between the wheelwells so it doesn't rub(which I've been doing)it's not centered on the runners. Anyone else had this problem? Also with the trailer backed in with maybe 2 inches of the top of the wheelwell above the water line on both sides, the boat will still load to the starboard side and not center.
07-10-2006, 8:11 AM
Contact boatmate they will take care of you. http://www.boatmatetrailers.com/
07-10-2006, 8:14 AM
I am taking it to the dealer tomorrow and they will file a warranty claim for the gelcoat repair. Just wondering if anyone had the misalignment issues or am I just lucky.
07-10-2006, 8:17 AM
I have a Centurion on a Boatmate it loads fine. Any issue I have had in the past with Boatmate trailers has been taken care of with no problem
07-10-2006, 8:24 AM
I have exactly the same problem with ours Randy. I did mention my concern about it being off center, but haven't heard anything from the dealer. Guess I will call Boatmate. No damage yet, and I will make sure to check the screws tonight. Thanks for the heads-up.
07-10-2006, 8:25 AM
My boatmate traielr has been flawless, w/ virtually zero maint.
07-10-2006, 8:27 AM
My Boatmate trailer that I had with my Moomba was flawless also. Not this time.
07-10-2006, 8:31 AM
I had the same thing happen, not bad at all though, just a small scratch on the bottom of the hull that I repaired myself. No one would notice if they were looking for it. It also bent the fender slightly and ripped a few screws from the carpeted side protector. I got it bent back in shape and put new screws in it, good as new. I think that the wife had the trailer too deep and that the trailer wasn't quite square with the water...the boat didn't engage the forward most bunks to center itself on the trailer. You really need to drive the boat up the trailer some to center it. However, I always look now to make sure I'm square with the world before I pull it out.
07-10-2006, 8:33 AM
My wife will load the boat and she is awesome at it. She had no problem with the Moomba, but after yesterday, she's getting really frustrated.
07-10-2006, 8:37 AM
Don't knwo about the 21v, but on my 22SSV My traielr is further out of the water than what I was used to on my old inboard. I "drive" up my bunks quite a bit. How far down in the water is your trailer?
07-10-2006, 8:38 AM
i hate my boatmate, i'm about to file a major complaint, i've wrecked to props now putting the boat on the trailer, the problem is the guide poles are too far out
07-10-2006, 8:41 AM
The trailer is backed in so approximately 2-3 inches of fenderwell are above the water on either side.
07-10-2006, 9:44 AM
The steepness of the ramp seems to have a lot to do with it. My Boatmate definately requires a more shallow entry than my previous trailers but then again this is the first tandem I've had (if that makes any difference). Anyway, on less steep ramps the boat goes on easier, centers better and you can put the trailer in a little deeper. The ramp I normally launch at is a little steeper than some but is not the steepest ramp I've seen. On this ramp I can submerge only a third to half of the fenderwell otherwise, if it is put in deeper, I have problems getting the tip of the bow to clear the bow roller (it wants to dip under) and the boat does not center as well.
07-10-2006, 9:50 AM
The steepness of the ramp does make sense however we are launching from same spot that we always launch from. When viewing the boat from the back when the boat is loaded, you can definitely tell that something is not square with the trailer.
07-10-2006, 10:18 AM
entrust, how far out are your guidepoles? Sounds like your trailer is in too deep. I've got a 22SSV and I rarely even touch my guid poles. IF your boat is on the bunks it's impossible to damage the prop, and you won't ever hit the guidpoles. Don't be afraid to drive up on your bunks.
07-10-2006, 10:33 AM
someone else backed the trailer in both times and it was a little to deep but still the prop shouldn't be damaged, the guide poles are to far out, they are 8" out! here is a diagram. if the boat touches the guide pole the prop hits bottom line
07-10-2006, 10:42 AM
your hitting the prop when taking ht eboat off the trailer? If so why not just put it in very deep and let it float off?? 8 inches does soudn a little wide, boatmate should be able to give you the exact dimenions. I've got noe mroe than 3-4 inches on mine (guess)
07-10-2006, 10:46 AM
Aren't the guide poles just that, a guide? I'd say something has gone SERIOUSLY wrong if you're up on the trailer and the rear of the boat is so far off to one side that it hits the guide pole and the prop hits the prop guard. I too have an SSV and it prefers to be loaded on shallow. (Message edited by Stanfield on July 10, 2006)
no i'm hitting the prop putting it on the trailer
07-10-2006, 11:08 AM
sounds like the trailer is way to far in the water --at the same time the guide poles are spread a little to far. try loading your boat w/ more of the trailer out of the water, come in slow and then let the trailer stop the boat. use the accelerator to run hte boat furthr on the trailer. w/ the traielr being too deep in the water, the rear of your boat is swaing from side to side causing you prop to hit the trailer/prop guard...
07-10-2006, 11:17 AM
like i said the trailer was in to far. i didn't back it down, regardless having the trailer 6" to deep shouldn't wreck the prop, the guide poles are too far so it you hit the guard rail you hit the prop
07-10-2006, 11:24 AM
Having the trailer 6" too deep won't wreck a prop. The combonation of coming in skewed and the trailer being 6" too deep certainly will. Where did your prop hit the trailer?
07-10-2006, 11:28 AM
the problem is the guide poles are too far out. they are 8" out and the prop only has like 8" of clearance. so if the boat swings out and hits the pole and the trailer is too deep it' the trailer
07-10-2006, 12:05 PM
Not trying to sound harsh, but IMO the guide poles are for rookies,if your putting the boat on the trailer correctly it is impossible for the boat to be out of position (hit your prop) as long as the bunks are correctly placed on the trailer. It took me about 4 years to finally realize this. lol.
07-10-2006, 12:45 PM
as i said, the trailer was a little too deep, so the boat doesn't sit on the bunks and hits the guide pole. i know you shouldn't use your guide poles to park the boat on the trailer but they still should keep the prop from hitting the trailer
07-10-2006, 12:59 PM
Entrust, that will probably happen on most boat/trailer combos. Having the rear end of the boat that skewed, regardless of how deep the trailer is, is going to cause the prop to hit something. Another warning to folks, if you have your trailer too deep and pull too far on to it, you can also run the risk of damaging your strut/shaft. That can happen on a SSV/boatmate setup and I'm sure it's not the only one so be careful. Not a lot of room for error back there where the business is.
