Not nkowing how you're jumping will affect that answer Keith. When you jump in the flats, do you ride level then lean back? Or, do you ride level, then dip towards the water and then lean back ( dip and pop )? If you're not doing a dip and pop, you should try and practice it. It helps your timing, as I've seen with some of our friends, when approaching the wake. Also, I've seen folks approach the wake with WAY too aggressive an angle of attack. When you statr with the wake jumps, try to picture youself landing in the middle between the wakes, right in the wash. Also, keep the chin up, don't bother looking at the landing site. Keep your body in one position ( rocking chair position ) hand low by the knees. Hopefully, this will help keeping you from the face plants. One more thing - DON'T PUSH WITH YOUR FEET! That's a sure way to get the nose of the deck down and a face plant coming up. Keep the tip of the foil up, at about a 45 degree angle to the water. Have Too Much Fun, Matt
