Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 26, 2009
Old     (homedawg678)      Join Date: Jan 2007       04-18-2009, 12:38 PM Reply
I am having a problem with what i think is my speakers cutting out. I have a 1997 Nautique super sport and the sound system is Clarion (well atleast the head unit). Whenever I try and turn the volume up above about 28-29 the whole thing will turn off and then turn back on until I turn the volume down. I was looking at the options and when i TURN THE bASS TO -7 AND THE treb to -7 they can go to about 30. Also, when i CHANNEL THE SOUND TO ONE SPEAKER OR THE OTHER IT CAN ALSO GO TO ABOUT 30 BUT THE SECOND i TURN THE BASS OR TREBLE UP, OR HAVE ALL 4 SPEAKERS PLAYING, IT ONLY LETS ME GO TO 28. Please help.
Old     (torquejr)      Join Date: Apr 2009       04-18-2009, 10:22 PM Reply
ok here is what you do you take your boat to
LPA-http://www.lostpro.com/ and http://sacramento.craigslist.org/bfs/1125712154.html
They can hook you up they address is
905 cotting lane Vacaville Ca 95688 and there shop # is (707) 449-9572
This was posted my LPA intern/web tec guy
(Message edited by torquejr on April 18, 2009)
Old     (jonyb)      Join Date: Nov 2008       04-18-2009, 11:50 PM Reply
All speakers playing off of the head unit or amps?
Clarion's IIRC only go up to about 35, so 28-29 should be the limit depending on what's powering the speakers.
Could be a dead short somewhere
Could be a blown speaker showing a dead short
Could be a low battery
Old     (bjeremi)      Join Date: Mar 2006       04-19-2009, 12:23 AM Reply
Ha nice plug Tim
"Coming At YOU!"
Old     (882001)      Join Date: Nov 2003       04-19-2009, 9:13 AM Reply
power issue. run a wire directly to battery just like an amp. problem solved.
Old     (882001)      Join Date: Nov 2003       04-19-2009, 9:15 AM Reply
run a new ground too. or run a new ground to the daisy chain under the dash.
Old     (homedawg678)      Join Date: Jan 2007       04-19-2009, 9:39 AM Reply
Whoops, sorry about the caps I just realized that. I think it's all running off, it says its 50 Watts x4 on the head unit. Where do I connect the wire to and from and everything. (I'm not so good at this stuff)
Thanks though!
Old     (j_money)      Join Date: May 2006       04-19-2009, 9:46 AM Reply
I had the same problem with one of my older boats... Pretty sure its the max that deck can put out..If I were you id get a 4 channel amp to juice those speakers with. 60 to 80 bucks for a nice fosgate or kicker and your set! check craigslist.
Old     (homedawg678)      Join Date: Jan 2007       04-19-2009, 1:25 PM Reply
We wanted to try and get a new system so I think we might just replace everything.
Old     (chucktronics)      Join Date: Nov 2007       04-19-2009, 5:24 PM Reply
that was a common problem with that year nautique (pretty much all of them with that style dash).
the ground wire is not large enough to feed all devices in dash, change that first by running a second 8 or 10 guage and parallel them in the dash pod . if that is not enough so the same with the power.(make sure to fuse them at the batt)
Old     (homedawg678)      Join Date: Jan 2007       04-19-2009, 6:00 PM Reply
What? I am complete noob at this.
