I have modified ours. I have a Monster Tower MT2 and we wanted a bimini top. But the legs swoop in so much it gets really narrow for a bimini. I ordered one that was in between the windshield width (where it was going to mount) and the width that I need to get inside the tower, about a foot difference. Then I cut the top tubes to make it fit inside the tower and carefully bent the angles to make the bottom width wide enough to reach the windshield mounts. I also ended up cutting a couple of inches off the main supports to make it a little shorter. It worked out great. The top looks good and functions great. The only issue is that I also have tower speakers and I can't fold the tower with it all connected. So I pull the pins where it mounts to the windshield and drop it lower, fold it over then pin it back to the windshield. But, yes - you can cut the tubes, bend the angles (carefully by hand) and cut and re-rivet the connector pieces if you need to.
