Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 04, 2006
Old     (skibum69)      Join Date: Aug 2004       07-13-2006, 9:17 AM Reply
No more waiting at the boat landing anymore. We spent the last few months working on the new boathouse and rail system. Works great, other than having to fold the tower down due to height restrictions on the boathouse.
The winch for the carriages
We will be filling in more rock as we find time
to space it correctly
Old     (ktmwakeboarder)      Join Date: Jun 2004       07-13-2006, 9:38 AM Reply
awesome!
Old     (bbeach)      Join Date: Jul 2002       07-13-2006, 9:45 AM Reply
I've always wanted to have a boat house like that! That is very cool! How much can your lift system be affected by lake levels? Or do the rails go deep enough in the water?
Old     (skibum69)      Join Date: Aug 2004       07-13-2006, 9:51 AM Reply
The rails go 50 feet into the water. We added 10 feet to our order incase the lake is low like it is now (12"+) I guess you could always add secions, but would have to get a new longer cable.
Old     (skibum69)      Join Date: Aug 2004       07-13-2006, 9:58 AM Reply
The rails go out to the bouys(milk jugs)
Old     (peter_c)      Join Date: Sep 2001       07-13-2006, 10:01 AM Reply
Nice setup, now you just need to set it up for remote control. It would be way cool to pull up on the lift, and press a remote too land you right in front of your boathouse :-)
Old     (skibum69)      Join Date: Aug 2004       07-13-2006, 10:04 AM Reply
Peter,
I do have it a remote system for it. It look just like a car remote for the door unlock.
I am also going to have water hose right by the door so I can rinse it down and wash it before it goes in
Old     (cawakeboarder12)      Join Date: Apr 2006       07-13-2006, 10:24 AM Reply
That is sweet I wish you could do that out here
Old     (innov8)      Join Date: May 2005       07-13-2006, 10:36 AM Reply
Very Sweet set up. How long does it take to winch it out or put it in the lake?
Old     (peter_c)      Join Date: Sep 2001       07-13-2006, 10:47 AM Reply
Jason that is definitely a sweet setup then :-)
Are you using some type of bang line, because that prop looks dang close to your rail car (Is that what they are called?). Something like a plastic covered cable mounted from the bottom of the car to the bow eye with a hook, or even something above the water would work.
Edit: Personally I would plant some grass between those rocks. It would blend right in with the neighbors grass.
(Message edited by peter_c on July 13, 2006)
Old     (skibum69)      Join Date: Aug 2004       07-13-2006, 11:39 AM Reply
It takes a little over a minute from full out to in.
Peter, we are using the yellow straps the go from the front of the carriage, to the back hooks on the transom. The prop is pretty close to the carriage, but when the boat is running you have to remember it is floating above the carriage. I shut off the engine when I get just inside the guide posts and let it float until I get the yellow straps hooked up. Then you hit forward and the straps keep the boat centered side-to-side and front-to-back until the carriage is shallow enough for bunks to hold the hull.
We were planning on planting grass between the rocks when we get the rocks to be spaced closer together. Actully, the grass you are seeing is ours, I was taking pics from our neighbors dock since we are replacing the wheel posts with longer posts.
Old     (skibum69)      Join Date: Aug 2004       07-13-2006, 1:08 PM Reply
Thanks for the nice comments everyone!
Old     (yosquire)      Join Date: Jun 2005       07-13-2006, 6:59 PM Reply
That's a lot of work. Why not build the garage high enough to house the boat with the tower up?
Old     (wakeslife)      Join Date: Jul 2005       07-13-2006, 7:24 PM Reply
Thats setup is awesome. Way to not just buy a boring old lift and go above and beyond!
Old     (badbob13ftw)      Join Date: Dec 2005       07-13-2006, 8:41 PM Reply
sweet set up .... and youre flying the pirate flag in youre profile ... nice
Old     (notsobueno)      Join Date: Dec 2004       07-13-2006, 9:02 PM Reply
Sweet sweet sweet!! Very nicely done.
Old     (mo_scrilla)      Join Date: Jun 2004       07-13-2006, 9:54 PM Reply
Wow ,you did a great job. We all wish we had a place on a sweet lake like that. That really takes alot of hassel out of going boarding.
Old     (skibum69)      Join Date: Aug 2004       07-14-2006, 11:00 AM Reply
Craig,
There is a height restriction of 12 ft. on the peak of any new boathouse, and they cannot have a flat roof. So, unfortantly I can't fit it with the tower up(otherwise I would have built it higher if I could). I am going to make a little cable system on the front of the boathouse that I can use to lower the tower backwards onto a stand I am going to place in the boat. Otherwise I think it's 150lbs or so to try to lower by hand.
Old     (skibum69)      Join Date: Aug 2004       07-17-2006, 6:05 AM Reply
Got some pictures with the tower down in the boathouse.Upload
Old     (greenpinky)      Join Date: Apr 2004       07-17-2006, 7:34 AM Reply
That setup is fuggin perfect!
