I ended up with an old beater baja bug and I'm trying to get it running. However, the brake fluid appears to be completely gone. It looks like a pretty simple system, so I put in some brake fluid and started the process of bleeding the brakes. However, nothing is happening. The fluid is not moving through the lines. There is no bleed fitting at the master cylinder, so I loosened one of the lines there to make sure fluid was making it that far and it is. The only thing I can think of is that the master cylinder is just not pumping and needs to be replaced. Any ideas?
