You will not be able to put a fat seat in that location. That is where the gas tank is. To remove the back seat on my '99, you lift out the top part of the seat. After taking out the top, you should see two pins that need to be removed from the bottom part of the seat. Then unlatch the rubber straps on the floor at each side of the bottom part of the seat. I hope that made sense.
