Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 15, 2008
Old     (lfrider92)      Join Date: Sep 2008       12-14-2008, 10:32 AM Reply
i have an i/o and we try and even out the weight as much as possible. and we do a good job for the most part. but is it normal to have one side of the wake better then the other? thanks guys
Old     (sidekicknicholas)      Join Date: Mar 2007       12-14-2008, 10:40 AM Reply
it maybe normal, I don't know I/O's well... but it is not what you want at all.... unless you're trying to learn a trick on a certain side or are a heelside hero
both sides should be clean, no wash or curl
(Message edited by sidekicknicholas on December 14, 2008)
Old     (chpthril)      Join Date: Oct 2007       12-14-2008, 11:36 AM Reply
Yes, the prop rotation tends to cause this. Instead of trying to split the weight even side to side, try adding extra weight to one side, then the other, and see how that does for you.
Old     (lffreak139)      Join Date: Nov 2008       12-14-2008, 1:08 PM Reply
I've got an I/O, and it's never done this really. You've just got to tweak it til it looks good
Old     (fordmxracer)      Join Date: Dec 2007       12-14-2008, 4:12 PM Reply
what travis said...Depending on the rotation of the prop, one side will be a little better but not enough to really matter.
Old     (lfrider92)      Join Date: Sep 2008       12-14-2008, 4:51 PM Reply
we have dual counterroatating props. could that do it? i ride regular, and cutting to jump heelside that side is better
Old     (mrboston187)      Join Date: Jul 2008       12-14-2008, 8:37 PM Reply
get some lead or sand and start counter weitghting on the other side, that might do it
