Old     (face_smash)      Join Date: Aug 2004       09-29-2007, 2:58 AM Reply
anyboady know where is a good place go get a set of rims for my trailer?? i would assume there needs to be a specific weight requirement or will any rims do??? thanks for the help!
Danny
Old     (rallyart)      Join Date: Nov 2006       09-29-2007, 9:26 AM Reply
Most rims will do just fine. You need to know the backspacing and diameter of the bolt circle. Check your tire rating and make sure the rim can handle the same load as the tire. That's usually not a problem. It's usually best to find one with the center hole the same size as your stock ones. That way the hub is taking some of the load instead of just the bolts.
They just need to fit under the fenders and clear the hubs and brakes to be OK.
Old     (face_smash)      Join Date: Aug 2004       09-30-2007, 4:48 AM Reply
thats Art that great!!!!
Old     (nautiquesonly)      Join Date: Sep 2007       09-30-2007, 5:46 AM Reply
Try a trailer supply store or tractor supply company You can get them there cheap if you are just looking for the standard white steel rim
Old     (xcharrier)      Join Date: Jul 2002       10-02-2007, 12:45 PM Reply
This is where I picked up a spare rim this season:
http://www.lowcosttrailersupplies.com/
Old     (tbonus)      Join Date: Oct 2005       10-02-2007, 5:20 PM Reply
What size, number of lugs, and bolt circle diameter do you need. About to upgrade my wheels off of my MC trailer. They are galvanized 14's with 5 lug on 4 1/2 bolt circle. Let me know.
