Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through July 21, 2005
Old    mark_mascioli            06-29-2005, 10:24 AM Reply
HEY ALL,
THE PROBLEM IM HAVING IS I CANT GET OUT OF MY BINDINGS.
THERE ALL RIGHT TO PUT ON(I USE SHAVING CREAM) BUT ONCE MY RIDES DONE.............IT TAKES FOREVER TO GET THEM OFF.
SOMETIMES I HAVE TO PULL SO HARD MY ANKES ARE SORE FOR A COUPLE DAYS.
DONES ANYONE HAVE SUGGESTION? MY BINDING ARE "CINCHWRAP" BY BLINDSIDE.
CHEERS
(Message edited by mark mascioli on June 29, 2005)
Old     (big_ed_x2)      Join Date: Jul 2004       06-29-2005, 10:28 AM Reply
Quit yelling.
get new binding.
Old     (dakid)      Join Date: Feb 2001       06-29-2005, 10:28 AM Reply
have you tried loosening the laces?
Old     (eternalshadow)      Join Date: Nov 2001       06-29-2005, 10:29 AM Reply
Some options for impossible boots, ask Walt, Monk, and Sean they know. There's the lie on your back and using both legs try and kick them off (like your doing some serious lying on your back squats as fast and hard as you can). The stand up and jump out of them (just like it sounds get the board underneath you and jump baby!). Or what I seem to be finding working the best is just bring your board close to you and start working it side to side and front to back (just wiggling it no hard wrenching) popping your feet 1/4 inch at a time until they start getting real loose then if they won't just pop out kick them off.
(Message edited by EternalShadow on June 29, 2005)
Old     (jarrod)      Join Date: May 2003       06-29-2005, 10:29 AM Reply
Or adjusting the bindings? I have a pair of those. They have adjustments. Just have to take them apart.
Old     (big_ed_x2)      Join Date: Jul 2004       06-29-2005, 10:30 AM Reply
That was funny Joe,I was gonna say the same thing just didn't wanna be a D#@K!
(Message edited by big_ed_x2 on June 29, 2005)
Old    mark_mascioli            06-29-2005, 10:30 AM Reply
i have tried to loosen the laces.....still no help
and big ed...........send me a check
Old     (big_ed_x2)      Join Date: Jul 2004       06-29-2005, 10:31 AM Reply
it's in the mail.
Old    mark_mascioli            06-29-2005, 10:33 AM Reply
i have already take the adjustment out(front part).
i dont want to take off the rear one because they feel loose as im wearing them...........anyways ed your no help
Old     (big_ed_x2)      Join Date: Jul 2004       06-29-2005, 10:36 AM Reply
ok sorry,try grabbing the board with boath hands,one hand on the front edge and the otheron the back edge and stick your elbow between your legs to get the leverage and twist
Old    mark_mascioli            06-29-2005, 10:38 AM Reply
thanks will do
Old     (kingskrew)      Join Date: May 2004       06-29-2005, 10:47 AM Reply
Crash harder...
Old     (mmobius2001)      Join Date: Jun 2004       06-29-2005, 11:46 AM Reply
i've tryed them all, the stand up doesnt work, i like the lie back and kick your feet a few times they'll pop right off.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-29-2005, 11:46 AM Reply
you can hurt your knees kicking them off. get longer laces.
Old    team909            06-29-2005, 12:02 PM Reply
moose juice before you ride and after
Old     (stephan)      Join Date: Nov 2002       06-29-2005, 12:11 PM Reply
If you have a swimstep get back up on it and stand there. Then you get two dudes (or big girls)to stand on the board. Then you get your third buddy to push you face first into the water. You will come out & it usually doesn't hurt. The other one is to do the wake jump to head dive, that always works pretty well.
Side note- These are more for the other people on the boat than for you, they will be laughting their arses off!
Old     (craiger)      Join Date: May 2002       06-29-2005, 12:34 PM Reply
1) cut out on your heelside to the outside of the boat
2) point toes up, turn board so your sliding sideways facing forward
3) point toes down
you'll be out before you know it.
Old     (stephan)      Join Date: Nov 2002       06-29-2005, 12:36 PM Reply
^^^Wear a mouthguard & a pillow under your vest for the above method ^^^^
Old     (skibum69)      Join Date: Aug 2004       06-29-2005, 12:38 PM Reply
That one if for the people in the boat too Craig!!
Old     (wakeme884)      Join Date: Jul 2004       06-29-2005, 5:34 PM Reply
put knob screws on the binding, when youre done just unscrew them and wear em as shoes..
Old     (tige_n_it)      Join Date: Nov 2004       06-29-2005, 7:26 PM Reply
At the end of your ride, go into a heel slide, then push down on your toes and lean forward. The force of the water will knock the board from you feet.
Old    james1978            06-29-2005, 7:31 PM Reply
1. Loosen all straps/velcro. Do another pull. Jump wake as u normally do, but with a lot of air, and dive head 1st into water.
2. Sit on swim platform, hang knees off the back of it so board is in water. Lean back, grab a handle. Have boat driver go as fast as he needs till board is off.
Old     (gtaussie15)      Join Date: Apr 2005       06-29-2005, 7:45 PM Reply
Well it seems theres a lot of comedians here. What I found to work and may have been mentioned previously, is you stand on the back platform have two of your friends stand on each end of the boar and then just pull yourself out, if that doesnt work, throw yourself forward and you should slip right out. I have the same problem with my friends LF super suctions, easy to get into, but a bit@h to get out of.
Old    foamy            07-01-2005, 8:56 PM Reply
put preperation H on your feet then they will shrink and ta da your out hahaha
Old     (damned04)      Join Date: May 2005       07-01-2005, 9:04 PM Reply
Sounds funny, but do ur bindings fit you properly?
Old     (rnopr8)      Join Date: Apr 2005       07-02-2005, 11:05 AM Reply
OMG....you guys just gave me the laugh of the day What's really funny is you are all right!!!!
Old     (jeffry)      Join Date: Feb 2005       07-03-2005, 8:16 PM Reply
What about soaking them in warm water?
