10-09-2008, 11:58 PM
Hey Guys and Gals, We picked up an 08 VLX, we are done for the season... What do we need to do to the boat? At the dealer, it said something about winterize your boat or something of that nature.. Can anyone explain this to me? Thanks in advance...
10-10-2008, 1:08 AM
You need to get all of the water out of the engine to prevent it from freezing and cracking the block. There is another thread on here with more details.
10-10-2008, 4:35 AM
I noticed your in NORCAL from your profile. Will you be storing the boat indoors? I'm in Folsom and keep my boat in the garage therefore I dont winterize my boat. Usually you dont get long hours of below freezing temps in Manteca, but if storing outdoors better to be safe than sorry!
10-10-2008, 9:15 AM
Probably a good idea to just bring the boat back to the dealer to have it winterized. There is more to it than just draining the engine. If your not running it for 4 or 5 months, then you will want the cylinders fogged too. Plus all the water drained from all the other systems too.
10-10-2008, 9:23 AM
Other systems, like the heater core Bill? ;) JT
10-10-2008, 9:26 AM
I don't think fogging the cylinders is necessary for a 4-6 month lay-up never done and never had a problem.
10-10-2008, 9:35 AM
Your best option here is to go buy a drysuit and just keep ridin all year!
10-10-2008, 9:42 AM
JT (peachman) ther systems, like the heater core Bill? ;) JT Yea, systems like that. Two nights ago I installed a pair of radiator Flush Ts in the heater lines down in the bilge. So now all I have to do is reach down between the serpentine belt & the muffler & pull those two caps.... gravity will drain the core in a few seconds. Tonite I'll get that heater back in the boat. And then we ride tomorrow at noon! Get your butt out here for a ride, JT!
10-10-2008, 9:49 AM
We store it in doors all year long and the boat just had it's 20hr service done to it... The boat only has 19 hours. I know, I don't ride as much as a should, but its been a busy summer...
10-10-2008, 9:54 AM
If your storing indoors I wouldnt worry about it. I've never done it and havent had any problems.
10-10-2008, 10:04 AM
Hey Shawn how cold does your water get? We were dry suiting last year in 42 degree water. We were just surfing so crashes weren't a worry and we could reach the riders feet with the hot shower. Good times!
10-10-2008, 10:12 AM
We were ridin all winter and water temp was about 49 at its lowest and air temp around 42. Definately good times!
10-10-2008, 11:56 AM
I'm with Shawn, take that beast out at least once a month and stay in wake shape. Drysuit and a thermos of cocoa/Bailey's and you are golden.
10-10-2008, 12:52 PM
And don't forget a cooler full of hot, hot water... We throw all our gloves, booties, etc... in the cooler so you have warm stuff to put on before you ride, then stand in the cooler to warm the feet/hands after a run. Oh and Big Heavy's cocoa/Bailey's suggest is golden! ;) JT
10-10-2008, 2:40 PM
Put some Stabil in your gas tank.
10-10-2008, 3:32 PM
Bill, I did something similar. I put those quick disconnect hoses on my heater lines. This allows me to simply "unplug" to drain the lines. It also allows me to bypass the core if it springs a leak. (I installed each line in opposite directions allowing me to connect the male outlet to the female inlet bypassing the heater core all together)... if it goes.
10-10-2008, 3:41 PM
Hey Liquidmx, I think I saw a sticky on the Crew site about how to install the quick disconnects. I looked at doing it in this location (under the engine) but didn't think I could connect/reconnect them very easily..... ie; one handed. I have used the flush Ts on an old boat, had pretty good luck with it & figured I could screw a cap on or off one handed pretty easily. Someone brought it to my attention that gravity may or may not be enough to get all the water out of the core though. So I've thought about installing a third one up by the core, under the dash. Then I could blow air or anti-freeze thru it easily. I like the idea of using quick disconnects under there & being able to bypass the core. So do those quick disconnects leak at all? My core is sitting right next to my subwoofer, that I don't want getting wet.
10-10-2008, 7:03 PM
i have never winterized and i keep my boat at orwood indoor storage. in brentwood. like said above. keep her in the garage and take her for a spin once a month or 2 and you will be more than fine. if you have absolutly no desire to use it until next summer then fine maybe drain the block, look in owners manual, d.c. the batteries and put a fuel stableizer in it.
