Daniel, On my 22i, I ran a hose under the seat in back. In the port side gull wing back storage area, there is a removeable plate. Take it out and you will be able to get to the hose and T it to both sides. At the very top inside corner is a gap that is big enough to run a hose through into the storage compartments. I hope this helps with the back. On the front I came up through the floor in the area under the seat right beside the driver (actually where I mounted my pumps). Then ran the hose along the starboard side up to the bow. Split it to both sacks. It worked pretty well for me. All of my balast is hidden. The pumps sing a little loud, but hey that is why I have a big amp.Send me a note if you need additional help. As far as the wiring being heavy enough, I don't know. I put in relays. Scott
