I have a 06 V-Ride and the sundeck is white and light gray. The light grey is discoloring uneven kinda as a camo effect. What is causing this and should it be coverd under warr. Any opinion appreciated.
Does it look like a protective layer is peeling off, sort of like a sunburn on your back? If so, maybe a warranty issue. If it's just discolored, then try cleaning it up as you might just have mold or general dirt problems.
is it always discolored or just after it has had water sitting on the vinyl? Sometimes you will see a camo pattern after water droplets have been allowed to sit on the vinyl for an extended period of time. If this is the case the discoloration will go away after the vinyl dries out completely.
no pulled the cover off today to clean all the vinyl and at 303 protectant. Found only the grey on the sundeck discoloring and it was not wet. The seats were ok. Could this be from the cover getting hot from the sun and lying against the vinyl. Why would it not discolor the white?
post some pics. so we can get a look. then make sure its clean, clean, clean and then let it completely dry as said above. if no change call your dealer/malibu for a professional opinion and start reading your warranty info. then go here....http://www.primalmp.com/
