Old     (freshtracks)      Join Date: Feb 2006       05-01-2008, 2:43 PM Reply
I'm sanding my teak for the first time. I want to know what you guys recommend for the grit?
thanks.
Old     (da_mose)      Join Date: Apr 2008       05-01-2008, 4:19 PM Reply
It all depends on how weathered the wood is but to be on the safe side start with 100 grit and see how it goes.
Old     (freshtracks)      Join Date: Feb 2006       05-01-2008, 4:28 PM Reply
and for the final finish? i want to make sure it's not too rough, while not slippery as snot! thanks.
Old     (rallyart)      Join Date: Nov 2006       05-01-2008, 5:14 PM Reply
Sand paper clogs really fast on teak. It's the high oil content. Use a scotch brite type stripping pad or use bronze wool. (Don't use steel wool) It will do a good job and you can reuse it every time you want to do the deck.
If you're going to use paper don't use finer than 100.
Old     (cla10beck)      Join Date: Dec 2007       05-01-2008, 8:09 PM Reply
I used 60 on mine, but it was in pretty bad shape. I didn't bother to sand with anything finer because the texture with 60 felt good and I was worried about making it too slick.
Old     (bigshow)      Join Date: Feb 2005       05-01-2008, 8:32 PM Reply
I used 60, 80, and 120.
Old     (kko13)      Join Date: Jul 2006       05-02-2008, 3:09 AM Reply
i just did mine over the weekend.i used 60 sand paper as well
[IMG]http://i218.photobucket.com/albums/cc100/kkotige/DSC01898.jpg[/IMG]this is what i started with.
[IMG]http://i218.photobucket.com/albums/cc100/kkotige/DSC01899.jpg[/IMG] scrub (i found some cheap labor)
[IMG]http://i218.photobucket.com/albums/cc100/kkotige/DSC01902.jpg[/IMG]sand rinse and let dry
[IMG]http://i218.photobucket.com/albums/cc100/kkotige/DSC01918.jpg[/IMG]apply oil
i am real happy with the way it came out not to slippery. its a little darker than some but i think its just the wood it always got darker than most when wet.
(Message edited by kko13 on May 02, 2008)
Old     (downfortheride)      Join Date: Jun 2005 Location: SLC, UT 5600'       05-02-2008, 9:52 AM Reply
Fresh ~~ I just did my buddies Teak just the other week and it turned out perfect. I did it all in 320 Grit with 3 different wet sands. Then I used cleaner then brightener and two heavy coats of Teak oil.
http://www.wakeworld.com/MB/Discus/messages/3183/560758.html
P.S.
The bottom looks as good as the top!
