i can get into my boots ok bit getting out takes about 5 minutes to get out. When im done my ankle feels kinda sore for and hour or two. i was wondering if any of you have a good and easy way to get out of your boots. hat to ask stupid questions
Have you tried any others just to see if it happens with all. Anyways you can squirt alittle soap down in the bindings or boots when you try to get them off helps, had to do that for someone before
When you're taking your board off,(sitting in the water) put your right hand on the top edge of the board and your left (or vica versa) on the bottom edge and just peel the board back. Once you've done that, take your foot and press on the heelside of the board and your other foot should slide right out. I always find it easier to sit in the water while taking the board off. Alot of ppl get out of the water onto the swim deck to take it off and this makes it harder. Btw, what kind of bindings??
at the swiss national competitions many riders put the board under water, they stand straight on it and do some movements like very fast walking. it works! second method seen: grab on the platform and jump heels over head in the water... I never tried this methods and i don's know if they are safe! Good luck.
