Old     (moomba55)      Join Date: Jan 2008       12-28-2009, 1:33 PM Reply
I noticed while under the boat the other day oil was leaking down the inside of the tire. Any idea what might be the problem? It is a boatmate trailer.
Old     (meathead65)      Join Date: Sep 2006       12-28-2009, 3:25 PM Reply
Most likely a failed inside grease or oil seal...do you have grease or oil bath hubs?
Old     (chpthril)      Join Date: Oct 2007       12-28-2009, 5:32 PM Reply
If it's an axle with brakes, it could be brake fluid from a leaking wheel cylinder or caliper. Try washing it off with just water, if it does, it's probably brake fluid, if not, it's oil or grease.
Old     (jnking)      Join Date: May 2004       12-28-2009, 5:48 PM Reply
Check the allen head oil fill screw on the hub assembly. I have had these back out and leak fluid on several occasions.
Old     (moomba55)      Join Date: Jan 2008       12-30-2009, 12:47 PM Reply
thanks for everyones help. i have oil bath hubs
