I've got a ch, ch, ch sound from the left side of the engine and can't figure out what it is. Engine runs smoothly, no leaks, and no loud knock from the valve covers. And can't feel a puff of exhaust from the manifold...any ideas?
95 super sport. 310 hp gt 40 w/600 hours. I tried the soap around the heads / exhaust manifold and didn't see any bubbles. The plugs on that side are all tight and carbon free...they look fine. It has new manifolds on it...probably less than 6 months old...I still don't have a clue.
Pretty boat. Soap won't work as it is too much pressure. A smoke machine(tool)would be ideal. Use a stethoscope or a piece of hose in your ear and with the engine cold listen for air escaping from the exhaust manifolds. Do not let it continue as it will cause damage if it is the manifolds. If the manifold is warped it will need to be removed and machined.
