I would say it is more like what is the difference between a chevy and a gmc. They all start with the same block, a GM Vortec 5.7L with heads, intake, and fuel injection w/ electronics. If I understand or have been told correctly, each mfgr adds exhaust manifolds, starter, alt, water pump, fuel pump, and tweaks or programs the control module for fuel injection, if so equiped. And with those minor differences you get hp ratings that vary from 315 to 340 from the same engine. GM does sell the blocks in various versions with different fuel injection- throttle body or multi-port, and with different heads- hence the closed loop cooling with the aluminum heads. There may be another difference or two on specific models, but overall it is minor. One interesting things that I saw on the new engines that Tige is offering called "GM Vortec" and put together by Marine Power- they mount the starter in a different position (on top of bell housing instead of on the bottom), use dual oil filters and alt. belts to help prevent you from being stranded. But overall the biggest difference between mfgrs. is the plastic cover over the intake.
