I have a Supreme V220 with the Proflight Swoop tower on it. I made a fiberglass speaker enclosure for it and I was trying to find out what is the best way to run the wires for it. Any help would be great.
Drill your holes top and bottom. Tape a vacuum to the bottom hole, feed a leader string in the top and the vac will suck it out the bottom. Attach your wires and pull. Too easy.
I used dental floss to get the leader string through... then pulled a stronger wire through with the dental floss... then pull the speaker wire through... in addition... I pulled through some more wires for lights and nav light and RopeWinder...
I tried the vacuum and string but the string kept getting hung up on something inside the tower. I ended up using a wire puller that I had previously purchased to pull speaker wires through the walls in my home and it also worked.
