Whenever one side of your wake washes out at the other is clean it is a signal that the side washing out needs more weight. You can clean up the washy side by either adding more weight to the wahsed out side or by draining ballast from the clean side until the washed out side cleans up. After you get to know your boat better you will have a very good feel for how to weight it based on how many people are in the boat. I typically ride with only one other person, so when there's a rider in the water that means there's only a driver in the boat. I typically fill the rear tank on the driver's side only half full to start and then adjust it during the first set. Usaully by the end of teh first set I've got it pretty dialed in.
