Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through February 24, 2008
Old     (sdmjr)      Join Date: Jul 2007       02-09-2008, 6:46 PM Reply
Can you mount any binding to the board ? I bought A roam today and want to mount my ronix cells to it. Do you guys know if there will be a problem with this?
Old     (mcwakerider)      Join Date: Dec 2006       02-09-2008, 7:05 PM Reply
no there shouldnt be. i mount my ronix ones on my roam but you may need to put an extra washer on the screws
Old     (sidekicknicholas)      Join Date: Mar 2007       02-09-2008, 8:17 PM Reply
I had no trouble w/ any boot
Old     (04outback)      Join Date: Jul 2007       02-10-2008, 5:54 AM Reply
I remember reading something about you were supposed to use the Hype screws... But I think it is like Billy F says.. you may need washers. I use LF bindings and like the spring loaded flip locks.. I have 05 and 08 Roams with this set up.. No probs on 05.. anxious to use 08
Old     (westsidarider)      Join Date: Feb 2003       02-10-2008, 2:40 PM Reply
the board is thinner so you need to make sure you have the right length screws. the board should have come with the correct size screws.
Old     (nickdakoolkat)      Join Date: Sep 2005       02-10-2008, 5:03 PM Reply
what they said^^^^^
Old     (hawkeye7708)      Join Date: Feb 2007       02-10-2008, 6:09 PM Reply
Jason is exactly correct. The board requires a specified screw. It comes with the board. I found this out after i bought it, and used regular length thumb screws and broke a binding off on my first set. After a call to Hyperlite they filled me in on the screw length thing. After i got me a few of those, i've taken alot harder falls on it, and theres been no problem.
Old     (elantz)      Join Date: Jul 2006       02-11-2008, 7:52 AM Reply
My first Roam didn't come with the shorter mounting screws, so I had to size some at the hardware store. My second and third came with the correct screws.
I see the older Roams in pro shops w/o the screws still, so it is possible to buy a new board w/o them. I'm sure hyperlite would send them to you, if you need them.
