Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 21, 2006
Old     (gary_in_ia)      Join Date: Jul 2004       06-27-2006, 9:11 PM Reply
I have a Humminbird depth finder with the thru-hull transponder. Any suggestions for a mounting location of the transponder in a 93 Sport Nautique?
Old     (sup208)      Join Date: May 2004       06-27-2006, 9:26 PM Reply
i mounted one of these before. it is kind of a pain. You need to mount it in a place that is always in contact with the water and you need to make sure the epoxy has ZERO air bubbles. My installation manual suggested putting some water in the bilge shile you are out on the water and test various locations in the boat. it's tricky
Old     (peter_c)      Join Date: Sep 2001       06-28-2006, 12:21 AM Reply
Under the water pump impellar. Starboard side.
Old     (biz)      Join Date: Mar 2004       06-28-2006, 7:16 AM Reply
I have a 95 Sport and mounted mine on the opposite side (port) lined up with the water pump impeller (of what Peter C wrote). Also, KJ has a good tip with the water in the bilge. I did this to find the best location and used small sand bags to hold the depth finder in one spot.
