08-12-2004, 5:13 PM
Any tip's about drilling and cutting holes in fiberglass would be greatly apreciated
08-12-2004, 5:29 PM
I have limited experience( installed PPass and tower) but here are a few tips. Always drill from the outside in, if possible. Use masking tape pressed down well over the area you are going to drill / cut and drill through it. Also we found scribing the gelcoat with a compass on the cut line prior to cutting eliminated any spider cracking in the gelcoat ( along with the masking tape). If possible use a new holesaw even for small holes. We had one that was 3/8 for tower bolt holes and it worked well. PPass holse was like 1 1/2 inch. PS new hole saw made all the difference.
08-12-2004, 5:30 PM
Blue tape. Reverse drill first with a hole saw. Same thing as the compass tip. Use wd40 and drill away. Are you using a hole saw or just drilling? If your just drilling, try to use a counter sink bit. (Message edited by oshensurfer on August 12, 2004)
08-12-2004, 10:53 PM
Hold a shop vacuum next to the hole you are drilling. No mess. And yes I agree, use tape.
08-13-2004, 7:57 AM
yea, tape, and a new bit if you're gelcoat is quality you won't crack it at all, scoring it before isn't necessary. I did try to drill a second hole with the original holesaw, and it took about 5 times as long, so a new one is probably a good idea. Oh yeah, make sure you are drilling in the right spot, then double check it about 30 times. Shop vac is a good idea, long sleeve shirt too (fiberglass dust burns and itches).
08-13-2004, 7:57 AM
As Scott said....DRILL IN REVERSE! I cannot stress how important this is. If you don't you will run the risk of chipping the gel coat around the hole. Drilling in reverse eliminates this problem.
08-13-2004, 5:04 PM
All your help is greatly apreciated. Can you use a jigsaw to cut out holes, I need to cut out a rectangular hole for a stereo, scares the heck out of me. What about a rotozip? Thanks again.
08-13-2004, 7:40 PM
Rotozip works great. Buy good bits for it, you'll need them. And go slow, don't force the bit, it will break. It will wonder a little bit so watch it.
08-15-2004, 9:24 AM
always countersink holes from the gelcoat side to stop spider cracks
08-15-2004, 9:28 AM
If your gonna cut out a hole with a jig saw,roto zip,then you should drill the corners(in reverse). Sort of a dot to dot trick.
08-16-2004, 8:36 AM
Just my .02 but I wouldn't use a rotozip. They have a tendency to get away from you. Trust me, you don't want to make a mistake on your gel coat. You only get one shot.
08-16-2004, 9:20 AM
If you are using a jigsaw, they make some abrasive blades for composite materials. They are not toothed like normal blades, but have a bead of abrasive welded to the front. I have not used it on fiberglass, but they work really nice on some other materials that don't cut that well with a toothed blade. As with anything new, try it on a safe place first or on a piece of scrap.
08-16-2004, 12:13 PM
You can use a Rotozip or even a Dremel tool with router bits. I used a Dremel with a cutting attachment and it really helps to keep it stable. Use a fresh bit for each hole - really makes a difference.
08-16-2004, 12:16 PM
I used a regular hole saw to drill the hole in my dash for my defroster vent, and went in forward with no problems, but then again I have a CC, and their gell is really thick.
08-16-2004, 4:37 PM
I used a rotozip to cut 6x9 speaker holes with no problems. Didn't use a drill bit to start either, just used to rotozip. Mask it first, mark the tape and go slow.
08-16-2004, 5:18 PM
Thank's again for everyones help! I think I have enough courage to do it now. Wich tape works best? low tack, tuck,or masking?
08-17-2004, 12:31 PM
Blue painters tape. Use the wide type or it may bind on you.
