I added a bow sac to my X-star (205V) by tying into the KGB sac pump as described in this thread:
http://www.wakeworld.com/MB/Discus/messages/3183/579077.html The problem is I can't get the system to drain now. The pump will pump water in and out the overflow. I flip the drain switch and I can hear the pump reverse and it sounds like it is pumping out, but no water comes out. I do have the yellow impeller in the pump. I even tried squeezing the KGB sac to force water down the hose to the pump, but it wouldn't pump. I tried isolating the system with the valves too draining just either the bow or KGB by itself, but no luck. It worked fine the first time out, but hasn't worked since? Not sure what the issue could be. Any ideas?
