Make sure you are standing tall at the wake just like any other trick. This can be hard at first because you will probably be concentrating on timing your trip-flip edge with the wake. Also, make sure you don't switch your edges too early or you will lose all of the speed of your edge which will result in loss of pop. Swtich your edge right as you start to go up the wake, not a second earlier. There was a couple of threads about this recently. If you do a search for them you will come up with some really good suggestions.
