Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 28, 2009
Old     (sailing216)      Join Date: Oct 2007       06-18-2009, 11:34 AM Reply
Impeller sticks sometime and I blow the fuse. I unscrew the plate, dislodge it (spin), and I'm good to go for awhile. I put some marine grease in there and didn't help much.
Any suggestions. What does the rebuild kit do?
Old     (jonblarc7)      Join Date: Jul 2006       06-18-2009, 12:29 PM Reply
I used to have the same problem, you just need to go to your dealer and buy the yellow impeller and you never have that problem again.
Old     (sailing216)      Join Date: Oct 2007       06-18-2009, 12:36 PM Reply
Awesome. Thanks for the fix.
Old    K.B.C.            06-18-2009, 12:38 PM Reply
yup, yellow impellers and a little lube and you should be good to go. I had the same problem everytime out for about a year. Switched to the yellows a few years ago and it hasn't happened once.
As a temporary fix, flip to empty as soon as you are done filling and vice versa. If you flip the impeller while they are still wet it usually works a lot better.
Old     (bchesley)      Join Date: Apr 2001       06-18-2009, 12:43 PM Reply
Actually they are green now. They are having a problem with the yellow ones spinning the black center peice out. The green are a compromise between the yellow and the orginal black ones.
Old     (sailing216)      Join Date: Oct 2007       06-22-2009, 10:29 AM Reply
I just ordered the Green ones from I think waterskiis.com, anyways I did a search for "ballast puppy impeller green". $9 shipping was BS but I'll be back on the water happy soon.
