Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 13, 2007
Old     (majorman22)      Join Date: Apr 2007       04-29-2007, 6:41 PM Reply
my raley attempts always look more like a backroll and i land on my back what is going wrong??
Old     (bigwaken2009)      Join Date: Oct 2006       04-29-2007, 7:20 PM Reply
Im workin on it. Cant land it yet. But iv learnded from my mistakes and you need to look at the tower just as your takeing off the wake. Some times I do it b4 I take off but ya. Still working on mine.
Old    alanp            04-29-2007, 8:26 PM Reply
youre not checking the trick tips section
Old     (fuller313)      Join Date: Oct 2006       04-29-2007, 8:44 PM Reply
Best thing to do is to look at the boat and let your legs go behind you. Practice on a trampoline if you can.
Old     (rothy)      Join Date: Jul 2005       04-29-2007, 9:19 PM Reply
That happened to me once when I was learning and it was because I didn't hold onto the rope so the momentum carried me around. It wasn't till I got that down that the bad crashes happened. Have fun and good luck staying out of the hospital.
This is what goes through my mind.
1. Load the line
2. Dont forget to jump
3. Look at the tower.
4. Bring it down.
-Don't look over at the landing it will cause you to spin. It's called stargazing.
Old     (jetpilotz)      Join Date: Mar 2007       04-29-2007, 9:20 PM Reply
you're probably letting go with your lead hand and star gazing
Old     (wakeviolater)      Join Date: Sep 2004       04-30-2007, 10:21 AM Reply
if your front foot flies behind you (like it sounds like your doing) you are too haevy on your back foot when leaving the wake.
Keep you weight even on both front and back legs when poping off the wake, and you'll do the raley without start gazing.
The same is true if your front foot heavy, but you'll rotate or glide the other direction.
Old     (ronnyboy27)      Join Date: Nov 2005       04-30-2007, 10:55 AM Reply
http://www.wakeworld.com/MB/Discus/messages/3184/408691.html
check out this post it gives great instructions
Old    110outlet            04-30-2007, 11:27 AM Reply
If you try to throw it at the bottom of the wake your going to spin super fast like a really laid out back roll that you land on your back, if you anticipate the trick and look up and over the wake to where your gonna land your going to spin like a backroll,if ya watch video of yourself you will probably see your board cutting up and away through the wake and your already in a leaned out position with your legs twisted already and wham spinning and landing on your back. Look at the wake, line up your jump and then look at the boat this will keep you from spinning. My first few where like that and then i over compensated and landed on my back going the other way like a Sbend, it was a rough first few attempts.
