Old     (dirty30)      Join Date: Aug 2006       04-16-2009, 10:10 AM Reply
i took some stickers off the side of my boat and it is scratching the gel coat.what do u guys use? i have tried tons if stuff but nothing works.
Old     (westsidarider)      Join Date: Feb 2003       04-16-2009, 10:15 AM Reply
what were you using to take the stickers off, razor blades?
The best thing to do is peel them off with just your hands and maybe a plastic putty knife or something similar if you need it and then use some goof off or even wd40 to remove the sticky backing left over followed by a light wax job
Old     (adam4x4)      Join Date: Jan 2009       04-16-2009, 10:17 AM Reply
Did you just a heat gun? Get it warm,then peal off and use goo-off to get the sticky stuff off.
Old     (bill_airjunky)      Join Date: Apr 2002       04-16-2009, 10:41 AM Reply
With sun & 80s in Cali you should probably be able to just leave the boat out in the sunshine for an hour or so, then peel them off with your fingernail.
I usually use the peeled off decal to dab at any left over adhesive, which will remove 90% of it, if not more. Then there are several adhesive remover products from the likes of Home Depot/Lowes like Goof Off, Goo Gone, etc. Some stink to high heaven & others have that fresh citrus scent ;)
Old     (sidekicknicholas)      Join Date: Mar 2007       04-16-2009, 11:03 AM Reply
blowdryer or something works well, any heat gun type thing..... maybe a razor just to start it, but then they go smoothly
Old     (lovin_the_wake)      Join Date: Jul 2007       04-16-2009, 11:05 AM Reply
heat gun or a hairdryer should work. I actually used this rubber wheel that our body shop uses to take off pinstripes and it was awesome it took about 10 minutes to do 3/4 of my boat
Old    Slingshot            04-16-2009, 11:10 AM Reply
Use a heat gun and a piece of plastic like quarter inch thick to get it started and you should be able to pull it off. Use Acetone to wipe the glue off. Make sure when you use the acetone not to touch anything plastic or other decals/stickers on the boat. It will mess them up.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       04-16-2009, 11:15 AM Reply
thin plastic with an edge.
Old     (tonysdad)      Join Date: Jul 2005       04-16-2009, 11:19 AM Reply
Heat them up with a blow dryer and use something plastic if needed. I used a credit card to get mine off. For the extra adhesive left behind I used 3M adhesive remover. It really does the trick.
