Help! High speed pump kicks on, stays on at all times. Replaced the relay, works for a bit and then does it again. Overheated, replaced the impellor (hoping that now the high speed pump wouldnt think it was starving for fuel). Now it does nto overheat, but the pump still comes on and stays on. Eventually burns out the relay. Now, wont idle. "Chugs" as if its gunked up somewhere, not getting fuel. Runs great at higher speeds, but will not idle, dies. The "low oil pressure" light comes on when the key is in, beeps intermitently at all times, oil was a lil low but nothin major...Tried changing out both fuel filters, still doing it, any other solutions?? Could it be the low speed pump? Sanger v210 w/ 350 merc mag. Thank you!
