I mounted the brain of mine under the dashboard. The unit itself comes with a RCA to mini jack cable so you can connect to the RCA input on your head unit. I went to radio shack and purchased a 3.5mm mini jack extension cable and you can run it all the way to the headunit. With mine, I used a 16 foot extension. So my setup went like this: The control unit is on my dash, the brain is under the dash, from the brain, I have a 16 foot mini plug extension cable, which is connected to the mini jack-RCA cable that came with it, which in turn connects to the headunit RCA in.
