Old     (loudsubz)      Join Date: Aug 2001       06-01-2008, 7:15 AM Reply
I installed the unit last night, everything is wired correctly.
The issue I am having is with the unit itself.
The first time I set it up, the unit was saying:
"Please Wait" and in the bottom left corner it said 02,1, and would not respond to any ACC input (in other words, it would not turn on/off with the ignition)
I had to reset the unit by pulling the power clip from the unit, then it worked after that.
Today I went to try it a second time, and it works with the ignition, but now the splash screen comes up saying H+K Drive + Play, but after about 3-4 seconds the unit turns off. I press the play/pause and it comes on again but turns off, and goes into this cycle, I can't get it to power on completely.
Theres no mention of this in the manual at all.
Old     (boarder_x)      Join Date: Mar 2006       06-01-2008, 7:37 AM Reply
I had the original in my truck. Mine worked fine, electrically, but had a LOT of static. I tried using the RF transmitter, and the antennae input. Neither worked. I'm pretty sure mine was just a bad unit. So, I only used it a couple times.
Old     (migitty)      Join Date: Aug 2001       06-01-2008, 10:00 AM Reply
Make sure your swtched wire is correct. Mine did the same thing. Try hooking it up for a second with the other power cord it came with. If it works that way, you the know the problem is with your ACC wire.
