Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through July 27, 2007
Old     (wakeboardmatt)      Join Date: Jun 2007       07-23-2007, 10:52 PM Reply
I ride an 05' hyperlite state, with the state bindings. I love the board and I have never had a problem with it until a few weeks ago. My rear binding had a jiggle to it so i tightened it and it seemed to fix the problem. A few minuets later, i cut out toeside and i can feel my rear binding tweak. It moved a few degrees. So I decided to call it a day. I went home and put in a new "claw" and it doesnt move when i ride anymore but a few days ago, the jiggle came back again. Any suggestions?
Old    sealyon.net            07-24-2007, 5:58 AM Reply
Without seeing it's them hard to say.
Make sure they are tight, and make sure when you tighten them the teeth are lined up properly. If that doesn't work try a little lock tight.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-24-2007, 7:22 AM Reply
keep a phillips in the boat
Old     (wakeboardmatt)      Join Date: Jun 2007       07-24-2007, 3:01 PM Reply
The screw is tight, but the binding still jiggles
Old     (bcmach)      Join Date: Apr 2007       07-24-2007, 3:14 PM Reply
then maybe try adding another washer to the claw if it's not tightening the bindings down
Old     (wakeboardmatt)      Join Date: Jun 2007       07-24-2007, 3:22 PM Reply
that would make it looser wouldnt it?
Old     (janzy)      Join Date: Aug 2004       07-24-2007, 4:44 PM Reply
I think what Brian is suggesting is that your screw is a bit too long. If that is the case, by adding another washer to the claw, the screw will be able to "dig deeper", thus is will be tighter, not looser.
Old     (wakeboardmatt)      Join Date: Jun 2007       07-24-2007, 5:58 PM Reply
ok, ill try it and get back to you
