Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 21, 2008
Old     (bamacpa)      Join Date: Aug 2006       01-26-2008, 3:59 PM Reply
I know a ton of threads are on this, but a quick question. I have taken out some small surface scratches with some 600 and 1000 grit sand paper. Now I'm left with dull spots where the scratches were, like the finish is gone. What is my next steps. Polishing compound, rubbing compound? Help please.
Old     (johnsvt)      Join Date: Dec 2006       01-26-2008, 4:02 PM Reply
I would use polishing compound with a wool pad. Then finish with polishing compound and foam pad. I would also try 2000 grit next time, takes a little longer but buffs easier.
Old     (mobv)      Join Date: Jun 2002       01-26-2008, 4:05 PM Reply
3M Finesse polishing compound with a foam pad is the best combination I have found.
Old     (fogey)      Join Date: Mar 2002       01-26-2008, 4:38 PM Reply
I second the 3M Finesse suggestion. That's good stuff.
Old     (bamacpa)      Join Date: Aug 2006       01-26-2008, 6:42 PM Reply
Do you need a polisher or buffer for the polishing compound or can it be done by hand?
Old     (johnsvt)      Join Date: Dec 2006       01-26-2008, 7:45 PM Reply
With using 600 or 1000 you will need a rotary buffer.
Old     (bamacpa)      Join Date: Aug 2006       01-26-2008, 8:23 PM Reply
Thanks guys for the help. Sounds like I should have tried a higher grit paper to start with. Thank goodness it is only a few spots on the transom. I've been thinking of getting one of these. http://www.autogeek.net/bupo.html
Maybe its time now. Anyone have experience with these?
Old     (mobv)      Join Date: Jun 2002       01-27-2008, 4:45 AM Reply
You can buff it out by hand, it can be alot of work depending on size and depth of marks.
I don't have the Porter Cable, I made the mistake of buying a Craftsman 2 speed angle buffer. The Porter Cable get great reviews and that is what I would buy if I could go back.
Gel coat is much easier to buff than clear coat on a car or truck. Doesn't burn or swirl if you work on slow speed.
